Question about GCX buffered Gutiar In/Out...
simspace
Post by simspace » Wed Jul 08, 2009 8:02 am
I just picked up a pre-owned GCX and GCP and I have a question about GCX buffered Gutiar In/Out...
When I use the GCX passive connection on the front and back panels direct to the amp, I hear my guitar.
When I use the buffered connection (guitar in/out) direct to the amp, I get no signal at all.
I've tried straight to the amp, through a loop, with the GCP connected and disconnected and still no signal.
I've read and re-read the manuals and I don't think I'm doing anything wrong. You have any ideas?
Chris
Chris (Fake Edge) Simeone
UZoo - The Unforgettable U2 Tribute Band
http://u2act.com
unix-guy
Re: Question about GCX buffered Gutiar In/Out...
Post by unix-guy » Wed Jul 08, 2009 9:16 am
Funny, I just had the same exact scenario about 2 weeks ago. I wrote in to Voodoo Lab tech support and was told I needed to send the unit in for repair: $35 + parts + shipping both ways...
I opted to just use the passive connections :)
Kevin
Gear List:
'87/'88 Ibanez Sabre's (7), '86 Ibanez PL1770, Budda SuperDrive 18, George L's Cables, Barber Direct Drive (best $99 ever spent!), Rodenberg GAS-828, Nobels ODR-1, Morley Bad Horsie II, TC Electronic G-Major II, Ground Control Pro and GCX...
Post by JohnClark » Wed Jul 08, 2009 9:54 am
You can check that the buffer's op-amp is seated properly in its socket, or check for any loose connections on the front panel jacks. But basically it sounds as if you bought a broken GCX. A dead buffer is not at all a common occurrence, which is why we would rather just see it for ourselves… we can get it fixed correctly the first time.
New gear comes with a warranty; Used gear comes with Vegas odds…
unix-guy
Post by unix-guy » Wed Jul 08, 2009 9:57 am
Is the op-amp easily identified on the PCB?
Kevin
Gear List:
simspace
Post by simspace » Wed Jul 08, 2009 10:05 am
K. Thanks for the reply John!
http://u2act.com
Post by JohnClark » Wed Jul 08, 2009 10:23 am
The op-amp is located on the PRE/PWR board, directly behind the front panel jacks... you can't miss it. Older units may have the op-amp soldered directly to the board.
