It is currently Tue Jan 16, 2018 12:32 am
 Post subject: tap tempo
PostPosted: Mon May 11, 2009 3:18 pm
regarding controlling delays with the GCX and ground control: i have a t rex replica delay which has a midi in the as this pedal uses midi to control tap temp through cc messages. Can somone tell me how to hook this up so one of my buttons on the ground control can be assigned to control the t rex delay?
 Post subject: Re: tap tempo
PostPosted: Fri May 15, 2009 3:24 am
I have a client wanting to do this as well. First need to figure out what CC# the Replica responds too. Should be easy to set up. What is your midi signal path? Are you running the midi cable straight from the Replica to the GC Pro or from the Replica to a GCX?
Connoisseur of good tone.
http://www.guitarpedals.co.nz
