G major 2 with GCX?
james
G major 2 with GCX?
Post by james » Sun Oct 11, 2009 7:55 am
I have a gcx and major 2 Can I connect them by midi or just run through loop of GCX?
Re: G major 2 with GCX?
Post by JohnClark » Mon Oct 12, 2009 10:01 am
Likely You will use both... the loops are switching the audio signal for a True Bypass when you are not using the G-Major 2. The MIDI is for controlling what the G-Major 2 and the GCX are doing.
