Removing GC Pro Rubber Feet?
Mr. T
Post by Mr. T » Sun Oct 11, 2009 10:14 pm
Been trying to remove the rubber feet from my GC pro in order to attach it to my p/board. Not sure if I'm being massively retarded, but no matter how much i try to loosen the screws, the feet won't come off.
Help!?
T
Re: Removing GC Pro Rubber Feet?
Post by JohnClark » Mon Oct 12, 2009 10:16 am
There are non captured nylon stop nuts (5/16) securing the rubber feet in place. Without grabbing on to these the screw in the feet will just spin. To remove the Rubber Feet on a Ground control Pro you will first need to remove the bottom cover. Remove the 4 button head screws on the top (5/64 Hex) as well as the 6 pan head screws on the bottom (#2 Phillips) to remove the bottom cover.
Mr. T
Post by Mr. T » Tue Oct 13, 2009 7:14 am
thanx again john.
T
