Gcx audio switcher---Gcp problem
rockman8812
Post by rockman8812 » Thu Oct 15, 2009 10:24 am
hello.
i hope you can help me with this problem.
sometimes when i turn on my gcx and gcp the gcx dosnt change loops. when i press a preset in my gcp and some loops must be activated the loop lights in the gcx dosnt turn on and the light that saids active works normaly at the same time.
why is this?
thanks a lot
mibu
Re: Gcx audio switcher---Gcp problem
Post by mibu » Thu Oct 15, 2009 12:55 pm
I think you get separate power for the gcx and gcp. you have to fire-up first the gcp, then the gcx.
Post by JohnClark » Fri Oct 16, 2009 9:51 am
Other way around... first power the GCX, then power the Ground Control Pro.
If you are phantom powering the Ground Control Pro and having this problem then likely you have a bad MIDI cable between the Ground Control Pro and the GCX.
mibu
Post by mibu » Fri Oct 16, 2009 10:04 am
oops... sorry john!... was in a hurry...
rockman8812
Post by rockman8812 » Sun Oct 18, 2009 3:47 pm
thanks a lot men , since i turn on the gcx first i have not this problem anymore
cheers
