Control Switcher and EVH 5150 III 100w
Manhell
Post by Manhell » Thu Sep 22, 2016 12:07 pm
HI there,
Where I live is really hard to get the custom cables for this so I probably have to have one made for me, can anyone tell me how's the wiring?
thanks
Re: Control Switcher and EVH 5150 III 100w
Post by JohnClark » Thu Sep 22, 2016 4:00 pm
You can get this cable directly from us and we can ship it to you... wherever you are ;)
Also, here is a link to a thread that has a diagram for how to build your own cable...
http://www.voodoolab.com/forum/viewtopi ... +iii#p9315
Manhell
Post by Manhell » Tue Sep 27, 2016 6:49 pm
Thanks john,
just tell me what happens if I use a normal Din 5 cable with our the common pin? will it do any arm or not work?
Post by JohnClark » Wed Sep 28, 2016 10:19 am
A standard MIDI Cable connected between the Control Switcher MULTI jack and the 5150 III 100W Footswitch jack will not work.
The cable must be wired as described in the thread mentioned above...
5 Pin End ---------------> 7 Pin End
1 ----------------------------> 1
4 ----------------------------> 3
2 ----------------------------> 6
5 ----------------------------> 4
3 ----------------------------> 2
Manhell
Post by Manhell » Tue Oct 04, 2016 7:03 am
IT WORKS :D
Manhell
Post by Manhell » Wed Oct 05, 2016 4:32 pm
The Fx Loop is kind of strange, it goes on an off but I change preset and it goes bananas.
How do I fix this?
Post by JohnClark » Thu Oct 06, 2016 9:31 am
Does your Control Switcher have the Black buttons or the Red buttons?
The version with the Black buttons cannot properly control the Effects Loop.
The version with the Red buttons can control the Effects Loop if you set Button #4 to Momentary Pulse On Pulse Off.
Manhell
Post by Manhell » Fri Oct 07, 2016 4:43 pm
It's the black buttons, can I do something to upgrade it?
Post by JohnClark » Tue Oct 11, 2016 9:25 am
You could upgrade to the newer model, but maybe it isn't necessary...
What else is in this rig? For instance, are the effects in loops of an audio switcher?
Manhell
Post by Manhell » Thu Oct 13, 2016 1:13 pm
luckly for me I want to incorporate a Line mixer with the GCX turning on and off the effects so I guess I can use the FX loop always open.
