It is currently Wed Feb 21, 2018 10:06 pm
 Post subject: Noise gate in GCX
PostPosted: Thu Mar 09, 2017 12:19 pm
Hi all, i'm new to the forum and am looking for tips on implementing a noise gate. Looking at the TC Electronics Sentry, and would like tips on hooking it up. Currently, all my loops are being used, but i can revise if you can offer some suggestions.
Signal chain is as follows:
Guitar in >GCX Audio Switcher powering a GCP
Loop 1: Earthquaker Tentacle
Loop 2: Wampler Ego Compressor
Loop 3: Strymon Mobius
Loop 4: Wampler Tumnus
Loop 5: Handmade clone of an amp eleven Lovepedal
Loop 6: Strymon Timeline (Routed to mesa boogie's effects loop)
Loop 7: Korg pitchblack tuner (using only the input of loop to enable silent tuning when engaged)
Loop 7 output to Mesa Boogie Lonestar Classic
Loop 8: amp channel switching
Pedals that seem to trigger noise are mainly the Ego, Tumnus and lovepedal clone, and tentacle when stacked into Tumnus. Where would be most logical placement of noise gate, and would using the gate's built in effects loop be logical to use here? How would any of you implement?
Ground Control Pro | GCX | ISO 5 | Mesa Boogie Lonestar Classic | Mesa Boogie Mark IV | Mesa Recto 2X12 | Gibson SG Standard | Gibson Midtown Custom | PRS Swamp Ash Special | '96 PRS CE24 |
 Post subject: Re: Noise gate in GCX
PostPosted: Thu Mar 09, 2017 4:07 pm
I would start off with all the front end effects routed thru the Sentry's loop. This way it triggers off your dry guitar but gates the signal just before the input of your amp.
1. GCX Guitar Out to Sentry Input.
2. Sentry Send to GCX Loop 1 In.
3. GCX Loop 5 Out to Sentry Return.
4. Sentry Out to GCX Loop 7 In.
PostPosted: Mon Mar 13, 2017 7:22 am
this was perfect, and the exact solution i was looking for. Thank you so much!
Users browsing this forum: Google [Bot] and 1 guest
