It is currently Wed Apr 25, 2018 3:42 am
 Post subject: Hex Amp Channel Selection
PostPosted: Mon Mar 20, 2017 11:34 am
Q1: The HEX is stated to use Isolated loop 1 for amp channel select. I have a MESA Transatlantic TA-15 that uses a foot switch to change amp channels. How do I wire Isolated Loop 1 to do this?
Q2 (in case Q1 is not fesible): The HEX is stated to use Isolated loop 1 as an A/B select.How do I wire Isolated Loop 1 to do this?
IT would be great to have documentation for this in the manual or somplace
 Post subject: Re: Hex Amp Channel Selection
PostPosted: Tue Mar 21, 2017 10:24 am
No problemo for either use...
1. Connect only the Out of Loop 1 to the Footswitch jack on the TA-15 using a standard instrument cable to have HEX control the amp Channels.
2. What do you want to A/B? If you will be switching between two amps you would route the audio signal to the In of Loop 1, the Out of Loop 1 would go to amp "A" and the Send of Loop 1 would go to amp "B".
