It is currently Sun Jun 17, 2018 5:18 pm
 Post subject: Using Control Switcher with Mesa MKIV Questions
PostPosted: Wed Mar 29, 2017 5:36 am
I am planning on using a musicomlab Efx 62M loop switcher to send midi signals to a Voodoo Labs Control Switcher to switch all 3 channels and the effects loop on my Mesa MKIV B head. to reduce cable bulk from the switcher to the amp (avoid 4 cable method), I am thinking of making an interface cable using a 20ft 5-pin midi cable and adding a 6 pin mini xlr on the other end to plug into the factory fu-3 footswitch din plug on the mesa head. Has anyone done something similar and will it work? Does anyone have a diagram of the pinouts for the 6 pin mini XLR(Mesa)end of the cable?
 Post subject: Re: Using Control Switcher with Mesa MKIV Questions
PostPosted: Thu Mar 30, 2017 10:52 am
We usually go with connecting to the amp via the 1/4" External Switching jacks.
Also, I don't have a reliable diagram of the Mesa footswitch jack, but often the channel switching is done on a single pin and requires some extra attention beyond just a simple connection between the two devices.
PostPosted: Thu Mar 30, 2017 12:35 pm
Thanks for the reply John, if i make a cable to use the 5-pin multi connector output of the control switcher and channel switching inserts of the amp, do you have a wiring diagram that shows me how to terminate the 1/4" ends?
PostPosted: Thu Mar 30, 2017 1:28 pm
No diagram of the cable but the Multi Jack pins are shown in the Control Switcher manual. The cable would simply have Pins 1, 3, 4, and 5 each connected to its own 1/4" Tip. Pin 2 would be the common connected to all four 1/4" sleeves.
PostPosted: Mon May 15, 2017 8:27 am
Hi John,
I have made a snake cable, 5 pin midi on control switcher multi end to 4 1/4 TS connectors on the external switching jacks end of the Mesa MK IV. It is wired according to your instructions in the last post. When I tested the control switcher(after setting the switch configure to latching) I am having trouble.
If I just have 1/4" cable #1 connected to the clean channel insert (ch.1 of mesa) and manually trigger switch 1 of the control switcher the channel works correctly. As soon as I connect another channel switching insert cable, say cable #2 to channel 2 (ch.2 )it affects the switching function even if switch #2 is off on the control switcher. I have checked continuity of the snake cable and everything checks out (tips of 1/4 TS ends to pins 1,3,4,5 and sleeves to pin 2 ground) any ideas what might be the cause?
PostPosted: Mon May 15, 2017 10:57 am
You say cable #1 works when by it self, but do each of the other cable ends work the same way when used individually?
Did you check for shorts across the plugs?
Users browsing this forum: Google [Bot] and 5 guests
