It is currently Thu Jan 18, 2018 12:20 pm
Post new topic Reply to topic  [ 8 posts ]
 Post subject: Ground Control Pro and Laney Irt studio
PostPosted: Mon May 08, 2017 3:31 pm
Hello guys, I have a question for you, I need your help.
I have a GCP and some stompboxes on my board. I use my laney Irt studio,
with his footswitch. The question is.. Is it possible use the GCP for changing the laney's channels? With a Midi cable?
Thanks you guys!! :D
 Post subject: Re: Ground Control Pro and Laney Irt studio
PostPosted: Mon May 08, 2017 8:25 pm
The Laney IRT is not directly MIDI controllable, but you can accomplish what you want with our Control Switcher. The Control Switcher will work with the Ground Control Pro to mimic the footswitch functions of your amp.
PostPosted: Tue May 09, 2017 12:35 am
Thanks! Therefore I have to connect the laney's footswitch on the GCP with midi cable ?
And then the GCP will work as a footswitch?
PostPosted: Tue May 09, 2017 10:46 am
The Voodoo Lab Control Switcher will replace the footswitch. The Control Switcher's MULTI jack will connect to the amplifier's Footswitch jack.
The Ground Control Pro will control the Control Switcher and whatever other MIDI gear you are using.
What are you controlling with the Ground Control Pro?
PostPosted: Tue May 09, 2017 10:52 am
Yes Recently I have purchased a musicom lab mkIII and I think that I could put the looper into a voodo lab switcher and then to laney.. in this case I can send a midi signal to my head and can changing channels
PostPosted: Tue May 09, 2017 12:01 pm
Oh, OK... in that case you would need a custom cable to connect from the FS1/FS2 and FS3/FS4 jacks on the MKIII to the Footswitch jack on your amp.
PostPosted: Tue May 09, 2017 12:13 pm
I need a midi cable right? Midi out of looper goes to midi in of switcher and then midi out of switcher on the head
PostPosted: Tue May 09, 2017 12:36 pm
Unless this is a new model that I don't yet know of, your amplifier does not accept MIDI. Your amp has a 5-Pin DIN jack labeled "Remote" but this is not a MIDI Input. This jack has four switch pins and a common ground pin. Making or breaking the connection from one of the switch pins and the ground pin will perform the different switch functions.
The TRS 1/4" "FS" jacks on your MKIII will interface with the IRT footswitch jack with a custom made cable.
The Multi jack on our Control Switcher will interface with the IRT footswitch jack using a 5-Pin Active MIDI cable.
