does the Control Switcher work with TRS (stereo ) jacks?
primerib
Post by primerib » Wed May 10, 2017 6:30 am
So I have a couple Splawn amps, and they use 2 TRS 1/4" jacks to switch the channels/modes and boost. Since the control switcher uses mono cables, can a Y splitter cable be used?
Like this one? Well, I suppose I would actually use 2 of these:
https://www.sweetwater.com/store/detail ... oCF3Lw_wcB
Re: does the Control Switcher work with TRS (stereo ) jacks?
Post by JohnClark » Wed May 10, 2017 9:20 am
Yes! An Insert Cable, like the one you linked to, is exactly what you would need here. You will need two of these to fully control the footswitchable functions on your amp.
primerib
Post by primerib » Wed May 10, 2017 11:21 am
Great, thanks for the help.
