Question about HEX and the loops
kungsmas
Post by kungsmas » Fri May 12, 2017 11:27 am
I'm planning on getting the HEX but I have some questions.
I have a Marshall Guv'nor boost in front of my Marshall JMP-1 and some pedals like delay, chorus etc in the loop of the JMP-1.
Can I use loop 1 on the HEX to switch on an off the Guv'nor and loop 2-6 to control the rest of the pedals?
Re: Question about HEX and the loops
Post by JohnClark » Fri May 12, 2017 12:30 pm
Absolutely!
Loop 1 is isolated from the others specifically so it can be used in a different part of the signal path. No problem at all to route Loop 1 in front of the amp and route Loops 2-6 in the Effects Loop.
kungsmas
Post by kungsmas » Fri May 12, 2017 12:36 pm
Great! I'm ordering one right now!
Thanx for quick answer. :D
