PX8 Plus: Using a loop as a channel switcher
g41nstr1v3
Post by g41nstr1v3 » Tue May 23, 2017 10:16 am
Hey there,
I just bought the PX8 Plus and I have a question regarding using it to switch between my clean and distortion channels.
I have an Orange Rockerverb Mk3 Head that i'm using and an orange brand two switch pedal that plugs in w/ quarter inch cables into the back (they can be plugged into the attenuation/channel switch/reverb jacks to control them with the pedal). I'm trying to get the PX8 to use its first loop for the channel switcher so i can create a present that will change the amp's channel and activate my other pedals with the push of one button (IE: so i can switch seamlessly to the clean channel from distortion and activate effects on top of it). Is there any way to do this? I've tinkered with it a bit, but i can't seem to figure it out!
- Dave
Re: PX8 Plus: Using a loop as a channel switcher
Post by JohnClark » Wed May 24, 2017 9:08 am
Dave's not here man!
Interesting screen name. You should meet forum user Gainstrive... he even has the same amp! :P
PX-8, and PX-8 Plus loops are not really meant for preforming amp channel/function switching, but the presets can be used to control a Control Switcher that is intended for channel/function switching.
The Control Switcher will interface to the amp using the same cables that would connect the Footswitch.
The PX-8 Plus presets will send MIDI commands to the Control Switcher and the Control Switcher will perform the amp footswitch functions.
p.s. PM me if you want me to make any adjustments to your user accounts ;)
