Tap tempo to Eventide eclipse and two H9
DrT
Post by DrT » Thu Jun 01, 2017 10:34 am
Can it be done with one IA? I'd like to tap the tempo for three units from the same switch
best
Jan
Re: Tap tempo to Eventide eclipse and two H9
Post by JohnClark » Thu Jun 01, 2017 12:46 pm
The best way to pull this off would likely be to have the first of these units generate MIDI Clock for the other two to receive.
The Ground Control Pro will control the Tap Tempo of the first device, then that device will send the MIDI Clock data to sync the other two. That all three are Eventide devices should make this a bit easier to do (hopefully ;) )
Let us know if you get stuck!
