PX-8 Plus and SDD-3000 pedal - MIDI question
stratguy866
Post by stratguy866 » Sun Jun 11, 2017 4:45 am
Just purchased and set up a new PX-8 Plus.
Just one question that I can’t seem to find the answer to anywhere…
In addition to using the preset mode to set various combinations of effects pedals in the loops, I am also controlling a Korg SDD-3000 pedal with it via MIDI. What I want to do is call up preset programs in the Korg to go with the pedals all with the push of one button on the PS-8.
Problem is I can only seem to get the MIDI program change commands sent by the PS-8 to correspond sequentially to the presets on the SDD-3000.
In other words…
1A on the PX-8 = 1A on the SDD
1B = 1B
1C = 2A
1d = 2B
And so on.
What would like to do is something like…
1A on PX-8 can = 5A on the SDD
1B = also 5A
1C = 7B
1D = also 7B
And so on…
I don’t know if I am doing something wrong (this is my first foray in to MIDI) or if what I want Is impossible.
I use the same delay sounds on a bunch of different presets on the PX-8 so it seems a waste to have a corresponding separate preset on the Korg. Also, the SDD-300 is already programmed with a whole lot of custom settings so I would love to avoid retrofitting everything.
Anyway, I hope this makes sense. Please advise.
Re: PX-8 Plus and SDD-3000 pedal - MIDI question
Post by JohnClark » Mon Jun 12, 2017 10:03 am
The Program Changes are fixed and cannot be re-programmed. You would need to map the sounds you want on the SDD-3000 to the patches the PX-8 Plus recalls.
Alternatively, you could use something like the MIDI Solutions Event Processor to convert the message sent by the PX-8 Plus to whatever message you like.
I hope this helps!
stratofloyd
Post by stratofloyd » Tue Jul 04, 2017 2:39 pm
Hi!
I've the same question. I need to switch some presets on my Strymon Timeline and my Mobius. I have to operate manually on both pedals, mapping presets in the sequential way I need, right?
For example, I can't recall on PX8 plus Bank1, preset 1
Bank 23A Timeline, Bank 02B Mobius...
Thanks in advance
Post by JohnClark » Wed Jul 05, 2017 10:22 am
stratofloyd wrote:Hi!
Thanks in advance
The PX-8 Plus presets will recall the Strymon presets sequentially starting with 00A on the Strymon pedals.
PX-8 Plus Bank 1 Preset A will recall Strymon Bank 00 Preset A.
PX-8 Plus Bank 1 Preset D will recall Strymon Bank 01 Preset B.
You will need to move the Strymon presets around to match the preset locations the PX-8 Plus will recall.
stratofloyd
Post by stratofloyd » Wed Jul 05, 2017 4:27 pm
Thanks in advance
Clear advice! Thank you! As I supposed, I have to move on Strymon presets :) !
Thank you! :D :D
