Help me JohnClark
Homero
Help me JohnClark
Post by Homero » Sun Jul 02, 2017 3:40 pm
Please John Clark
How i Connect this ( Midi & Conf. )
Rocktron Piranha + T.C Eletronic G-Force + Ground Control Pro
thank you
Homero :|
Re: Help me JohnClark
Post by JohnClark » Wed Jul 05, 2017 10:31 am
If you have a 7 Pin MIDI Cable, you can use the Piranha to provide phantom power to the Ground Control Pro.
1. Ground Control Pro MIDI Out ---7 Pin MIDI Cable---> Piranha MIDI In.
2. Piranha MIDI Out/Thru ---Standard MIDI Cable---> G-Force MIDI In.
You will need to name the Piranha and the G-Force as MIDI devices in the Ground Control Pro. This is shown in the Device Name/Channel section of the Ground Control Pro user manual under Setup.
I'd suggest setting the Piranha to use MIDI Channel 1, and the G-Force to use MIDI Channel 2. You will also likely need to program the Piranha to set the MIDI Out/Thru jack as a Thru.
Let us know if you get stuck!
