Voodoo Lab Hex switcher
claxor
Post by claxor » Tue Aug 01, 2017 10:34 am
Do any of you have trouble with "clicks" or "pops" when you push any of the front buttons to change loops? Rjm has a "click-stopper" in their switchers, and I wondered if the VL Hex had something similar.
Re: Voodoo Lab Hex switcher
Post by JohnClark » Tue Aug 01, 2017 10:57 am
Hex has an output buffer that features our Quiet Switching circuit. Quiet Switching will gently mute the Output whenever a loop is switching. It is programmable for a Short interval, Long Interval, or Off and can be set to trigger independently from Loop 1, Loops 2-6, or both.
For those that don't want anything in the signal path, the entire buffer can be removed 100% via a pair of internal jumpers.
