Hex Audio Loop
tbrogit
Hex Audio Loop
Post by tbrogit » Thu Aug 03, 2017 6:38 am
Quick question on the isolated loop on the hex. I don't find it very useful unless I'm misunderstanding its capabilities. I would like to use it as a typical pedal loop allowing that effect to be coupled with loops 2-6. How can I un-isolate it:)
also if I added another hex how would I use just one controller to operate both. Use Midi in on the first and use midi out to midi in on the second. So essentially run in series?
Re: Hex Audio Loop
Post by JohnClark » Thu Aug 03, 2017 9:48 am
Adding Loop 1 to the series is as easy as running a patch cable from the Out of Loop 1, to the In of Loop 2. This will put Loops 1-6 in series.
For the MIDI connections, yes this is just done in series as follows...
1. MIDI Controller MIDI Out to HEX #1 MIDI In.
2. HEX #1 MIDI Out to HEX #2 MIDI In.
tbrogit
Re: Hex Audio Loop
Post by tbrogit » Thu Aug 03, 2017 10:28 am
Excellent thanks
