It is currently Thu May 24, 2018 4:30 pm
 Post subject: PX8+ insert loop problem
PostPosted: Fri Sep 08, 2017 12:44 pm
Hey guys
I just set up my PX8+ loop switcher on my board. When I insert any jack into the input or output of the insert loop, the whole system will shut all sound off. Im running a volume pedal and a boost out of that insert loop between loops 6/7. I have tried just running the volume pedal and nothing else changed. I dont know what the problem is.
Thanks, Ty
 Post subject: Re: PX8+ insert loop problem
PostPosted: Fri Sep 08, 2017 8:32 pm
If you wanted your volume pedal in the Insert you would need to connect the Insert Send to the Volume Pedal Input, and the Volume Pedal Output to the Insert Return. Is that what you are doing?
PostPosted: Fri Sep 08, 2017 8:52 pm
yes sir thats what I am doing. It doesn't even read any signal once i put any input jack into the insert slot. It automatically just shuts off all signal.
PostPosted: Fri Sep 08, 2017 9:18 pm
Unless you complete the path back to the Return, connecting only to the Send will stop any signal from the Input and loops 1-6 from reaching the final output.
As a test, try the following...
1. Connect your Guitar to the Input.
2. Connect a patch cable from the Insert Send to the Insert Return.
3. Connect the Output to the Instrument Input on your amp.
With all Loops turned Off, you should hear your guitar thru the amp. Does this work?
