It is currently Mon Jul 16, 2018 11:04 pm
Post new topic Reply to topic  [ 9 posts ]
 Post subject: Pedal Order Does It matter
PostPosted: Sat Oct 21, 2017 9:24 am
Hi, I have been a GCX/GCP user for a number of years. I use it for amp switching and effects and some midi. I have decided to now incorporate all my pedals in to the units.
My question is this. Where is the order of the effects made? Do I install the pedals at the GCX in the order/groups I want or is it at the GCP in the order I assign to the switches? Does it even matter?
Thanks for the advice.
Bboy
 Post subject: Re: Pedal Order Does It matter
PostPosted: Mon Oct 23, 2017 1:33 am
yes, it does matter the same as it matters when you connect them on a floor pedal board.
The signal path is dictated by the GCX not the GCP, so you still need to think about where they go in the signal chain, what works best in what order. For example you wouldn't want to place a boost pedal in loop 1, ideally you'd place that at the end in loop 8 as the last effect before it hits your pre-amp.
Effect selection on the GCP has no baring on the signal path, it just selects what effect is in use. So you could actually have the boost in loop 8 of the GCX, but you can set it up to switch on and off with button 1 on the GCP.
David Gilmour
PostPosted: Mon Oct 23, 2017 10:25 am
Hi, thanks for the information. I kinda thought that, but wanted to make sure.
I'm guessing that if i want certain pedals say for acoustic guitar I would group them on there own? Does it matter as long as I put all my pedals in the proper order. I can select them as a group on the GCP?
Bboy
PostPosted: Tue Oct 24, 2017 12:20 am
If you are going to use some effects exclusively for acoustic you could split the GCX, as you say. For example,
You could use loops 5 thru 8 as acoustic loops, with the guitar plugged into the input of loop 5 and have the send of loop 8 going direct to the DI into the PA, and then use loops 1 thru 4 as electric guitar loops in the normal way. Or you could just use one loop for acoustic....... It's really up to you.
I'm sure I've explained this slightly incorrectly..... John Clark will probably give you a better way of rigging it up... But effectively you can split the GCX.
David Gilmour
PostPosted: Tue Oct 24, 2017 11:33 am
The order the loops are wired in is the order the signal will flow... so if you run loops 1-8 in series then Loop 1 will always be first in the chain and loop 8 will always be last.
However, this is a true bypass switcher so the order really only comes into play when loops are active as bypassed loops remove the effect from the signal chain completely.
About grouping the effects, I suppose generally grouping them would just preferred at least if to just be able to keep track of whats going on, otherwise I have the same question as bettsaj... is the Acoustic path completely separate from guitar to amp or do you just sometimes pull the guitar cable out of your electric and pop it into your acoustic guitar and you share any effects or amps between the two? Also, does the acoustic have a magnetic pickup system or is it piezo... or something else?
Let us know what you can!
PostPosted: Thu Oct 26, 2017 12:38 pm
Hi, thanks for all the input.
I'm not sure if this matters is that i have 4 GCX units now and a number pedals I have not used and want to put them back into service. Hence the makeover.
I understand the active and bypass functions and that I need to set pedal order up on the GCX units.
i would like to make it is as simple as possible at the GCP. I mean programming them to reduce tap dancing. Maybe John or anybody else could make suggestions.
The Acoustic section was a just an idea. I would like to share effects with both electric and acoustic, but would go to a separate acoustic amp if possible.
The Baggs DI is something I'm not sure where to place it in the loop.
I know i can assign each pedal individually on the GCP via Instant Access. Then maybe assign say Acoustic to a Preset?
I'm going deeper than I have used the units for before. I used two before for amp switching, reverb on/off, etc.
I hope this clarifies things ????
Thank You
PostPosted: Tue Nov 21, 2017 9:58 am
hi, just some more thoughts.
I'm thinking that GCX1 -2 would have my pedals in the correct order.
Then GCX 3-4 would handle amp switching and boost, channel switching.
I take it effects would come first,then amps and switching.
All help would be appreciated here.
A few more questions.
Where to place a BAGG acoustic DI in the chain?
I have a BOSS GTPRO and I'm wondering where to place it. It does go out to its own to amps and I want keep it independent of the rest of the system. Maybe someone has a method to allow it into the system and then if I want choose a pedal to bring into the GTPRO. GTPRO does have an effects loop.
Thanks for the help
Bboy
PostPosted: Sun Dec 17, 2017 6:10 pm
Noob here. So, just to be clear, the signal flows from loop 1 to loop 8, correct? Would I be correct in assuming that if I wanted to cascade gain pedals, I could do it with separate loops? Thanks!
PostPosted: Wed Dec 20, 2017 2:36 am
Each loop in totally independent to the next, so to connect each loop to the next you have to use a patch cable from one loop to the next loop. This being the case you can in effect split the GXC, say loops 1 thru 4 can be for analogue pedals like distortions etc, with the output of loop 4 going to the input of your amp. Loops 5 thru 8 can be wired into the effects loop of the amp for digital and modulation type pedals. But yes, essentially you are correct, the loops are normally used in series.
If you wanted to you could put 2 distortion pedals in one loop, so you could achieve what you want....... It's really up to you. Just because they're independent loops doesn't mean you can't experiment. I have a big muff in one of my loops, but i also have a Boss GE7 in the same loop after the muff to get rid of the scooped mids that the muff is famous for, it helps it cut through more during solos etc (I got that idea off David Gilmour, as he has a GE7 in the same loop as all his muffs)
David Gilmour
cron
