Hex failure - will not save presets
AaronJ16
Post by AaronJ16 » Sat Nov 04, 2017 8:46 am
Update: I fixed the issue. For anyone else experiencing this problem, make sure your midi device is sending on the right channel. I was able to reset the device and now HEX is able to save again.
Thanks, and sorry for the fire alarm!
Hello,
Wondering if there's a solution or if my relatively new Hex is shot (<6 months). It did this once before a few weeks ago and then started working, only to fail again. I cannot save presets, which makes Hex useless for me. I have another one coming with the intention of inserting into a rack. I'm regretting my decision now.
Is there a fix? Is this a known issue?
Aaron
Re: Hex failure - will not save presets
Post by JohnClark » Mon Nov 06, 2017 10:57 am
Glad you found the real problem!
