It is currently Tue Jan 16, 2018 1:56 pm
 Post subject: How to control a 3 channel amp switcher via MIDI
PostPosted: Thu Nov 16, 2017 9:26 am
Hi folks I need your help.
I currently use a palmer triage to control 3 different amps that I'm using live. I love it. Quiet, built like a tank, and eliminates any phase issues etc.
I am currently using Ableton Live to trigger changes on my m9, but would like to start using ableton to control the triage as well so that I am "tap dancing" less. i.e. I'm using a Marshall, AC30, and Fender Twin. Sometimes all 3 are engaged and sometimes it is a combination of two, one or none. How can I automate this? Again, no channel switching within the amps themselves - simply ON or OFF.
1. Is the MIDI Hex a way to do this? If not - what could and do so taking up the least amount of real estate. I'd like to keep everything on my board and stay under 50 lbs. and avoid a rack mount scenario if at all possible.
2. Is there a piece of gear out there that receives MIDI that could replace my triage?
Please advise.
Chet
 Post subject: Re: How to control a 3 channel amp switcher via MIDI
PostPosted: Thu Nov 16, 2017 1:40 pm
We don't really have a good solution at this point. :(
I don't see any way to use HEX to help. Our GCX could be used after outputs of the Triage to mute/unmute amps (Triage would stay with all amps active) but not only is it a rack device, I think it would be major overkill here.
It is possible that the Triage could be modified to effectively replace the switches with 1/4" jacks... then interface with our Control Switcher to "MIDIfy" your current setup, but I cannot say for certain having never seen inside the Triage box.
Sorry I can't be a better help here!
PostPosted: Thu Nov 16, 2017 2:30 pm
No worries! Thanks for trying to help me. Your customer service is top notch.
Users browsing this forum: Google [Bot] and 9 guests
