It is currently Thu Jul 19, 2018 12:37 pm
 Post subject: Use Line 6 Helix to control the GCX Ground Control
PostPosted: Sun Nov 26, 2017 1:33 am
Just trying to figure out if its possible to use the Line 6 Helix LT to control the Ground Control? I've been messing around with the 'Command Centre' part of the Helix menu all evening, can't seem to figure it out.
It says in the GCX manual that it midi channel is #16 by default. Can anyone help? Any help would be much appreciated :!: :?: ;)
Jordan
 Post subject: Re: Use Line 6 Helix to control the GCX Ground Control
PostPosted: Mon Nov 27, 2017 1:01 pm
Wait, do you have the Ground Control or the GCX... or both?
The GCX (our rackmount loop switcher) does indeed respond on MIDI Channel 16. Loops 1 - 8 respond to Control Change messages 80 - 87 respectively. A Data Value of 0 turns a Loop Off, and a Data Value of 127 turns a Loop On.
The Ground Contorol Pro (our MIDI Foot Controller) will respond to MIDI Program Changes and can be set to respond to whatever MIDI Channel you would like.
The original Ground Control does not have a MIDI In so it cannot be controller externally.
