Px plus general set up before programming
Boneguitar
Post by Boneguitar » Thu Dec 28, 2017 4:35 am
Good morning voodoo lab forum,
I need advice or help. Just purchased the px plus dingbat board
I want to make sure I am setting this up correctly
Here is the signal path
Guitar to pedals( always in use pedals)
Out of the last pedal into the input on the px-8
I have 5 pedals in the loop right now so loops 1 through 5 are in use
To each of these loops I am using the send to one pedal and output of the same pedal back into that specific loop
Then I am using the main output back to the amplifier
Am I doing something wrong I am not having success at this point...
Cheers and thank you for any thoughts or recommendations!
Boneguitar
Re: Px plus general set up before programming
Post by JohnClark » Wed Jan 03, 2018 11:04 am
Your description of the setup seems fine. What problem are you having? No signal at all? Dry signal but no effects?
