Evh to px-8
Gblankley
Evh to px-8
Post by Gblankley » Wed Jan 31, 2018 3:02 pm
I need to know if the px-8 will Be compatible with the evh I need to to be able to switch channels using the px-8 thanks for any info!!
Re: Evh to px-8
Post by JohnClark » Wed Jan 31, 2018 4:07 pm
The PX-8 and PX-8 Plus each send MIDI Program Change messages with their presets.
If your amp is directly MIDI Controllable (5150 III 50 Watt) then you will need only a MIDI cable.
If your amp is not directly MIDI Controllable (5150 III 100 Watt) then you will need something like our Control Switcher to control your amp with PX-8 or PX-8 Plus presets.
