GCX Switcher - changing loops with Ableton
jumo
Post by jumo » Sun Feb 04, 2018 4:29 am
Hello guys,
we are having a quick question. For our live setup we want to change the loops in the GCX Switcher directly with Ableton (we have a live project with bpm and backing tracks so we want to automate the changes in the GCX Switcher as well if possible).
In the manual we read that this should be possible (so the changes are not controlled by the Ground Control Pro, but directly by a DAW or other midi device). For that purpose we also got a * midi cable (pin 1 and 3 not wired). We connected the cable with the pedal in input at the GCX Switcher, but we are not sure how to send commands that the GCX Switcher can process. We made a new midi track with an empty clip, and put CC information into channel 16 in the midi clip. We thought that the values in that clip might change the loops and start/stop them. The midi track output of our interface we left at channel 1. There is nothing happening so far - so are we on the right track?
We would really appreciate some help - we are not sure what to do otherwise.
Thanks so much!
Re: GCX Switcher - changing loops with Ableton
Post by JohnClark » Mon Feb 05, 2018 1:42 pm
A GCX responds to MIDI Control Change messages 80 - 87 on MIDI Channel 16. A Control Change value of 0 turns a Loop Off, and 127 turns a Loop On.
jumo
Post by jumo » Tue Feb 06, 2018 1:35 am
Hi John,
thanks so much for your reply.
We read what you wrote in the manual but we are not sure if we routed everything correctly.
So in Ableton we have the track and can choose a midi channel to output midi commands for the whole track. We can choose a channel between 1-16.
And then we have the clip that send cc commands where we can add cc changes for channels 1-119. So which channel "16" do you mean?
Is it the track midi output channel, or the cc commands channel?
If it is the midi track channel, which channel for the cc commands do we need to use?
Post by JohnClark » Tue Feb 06, 2018 10:37 am
Sorry to not be completely clear!
MIDI Channels are numbered 1-16, the transmitted MIDI Channel must be Channel 16 for the GCX to respond. In MIDI this is the only thing referred to as "Channel", so this will be what you are calling your "Track".
The Control Change numbers have to be 80 - 87, Loop 1 responds to Control Change number 80... Loop 8 responds to Control Change number 87. A Control Change has a data value associated with it of 0-127... If you send Control Change 80 with a Data Value of 127, Loop 1 will turn On. This will be what you are calling your "Clip".
I'll try to help as best I can, but you may want to pose this question to an Ableton forum since what you are really asking is "How do I make Ableton Live send Control Change messages 80-87 on MIDI Channel 16?"
Let us know if you get stuck!
