Hex as an input switch?
Sonhenry
Post by Sonhenry » Fri Mar 09, 2018 8:52 am
Hey all
I'm struggling with a question I can't seem to make work. I'm wiring a hex to toggle between presets for a guitar and a pedal steel. The effects routing works great, but I want the preset to also change the input sources for me. I've tried input 1, normal and return as a option but the noise is extreme. Same using #2. Am I missing something, or is this just not workable?
Re: Hex as an input switch?
Post by JohnClark » Fri Mar 09, 2018 11:58 am
The Return jacks are ground lifted. You will need to do something like connecting the sleeves of the plugs in the Return and Out on Loop 1 in order to re-establish this ground connection.
Let us know if you get stuck!
Sonhenry
Post by Sonhenry » Fri Mar 09, 2018 1:59 pm
Ok, that makes sense. A little soldering and it's working. Thanks!
