Line 6 Pro modules with pedals (lots)
Plexico
Post by Plexico » Tue Dec 22, 2009 11:11 pm
Hi - I have the 3 Line 6 Pro units - the mod, filter and echo. I have two GCX's and the Controller to manage these rack units as well as the following pedals. I am trying to split into 2 amps:
Pedals
To LEAD AMP (#1)
Boss DD2
MXR P-90
Homebrew Detox EQ
Xotic RC Boost
Fulltone Soul Bender
To RHY/CLEAN (#2)
Ethos Overdrive
Ibanez TS 808
Way Huge Aqua Puss
Boss DD3
Line 6 Echo Pro
Line 6 Filter Pro
Line 6 Mod Pro
(WILL MIDI ALLOW 1 LOOP FOR ALL 3 EFFECTS?)
Since I am splitting into two distinct paths, what is best way to wire the Line 6 modules?
Many, many thanks and Happy Holidays!
Re: Line 6 Pro modules with pedals (lots)
Post by JohnClark » Thu Dec 24, 2009 10:35 am
You can put as many devices in a single loop as you wish. Is the amp split a strict A/B switch or do you run both at the same time?
Plexico
Post by Plexico » Thu Dec 24, 2009 8:37 pm
Hi -
Merry Christmas to you and thanks for the response. Ideally, each effect would have it's own loop so I can trigger them on/off as needed. Amps would be wired so only one is one at any given time.
Post by JohnClark » Mon Jan 04, 2010 10:30 am
The effects would connect to the GCX loops wired in series as is most common. The amps would be connected as per Example 2 in the GCX manual under A/B Switching. There are quite a few rig diagrams that contain these elements and more at http://www.voodoolab.com/gcx.htm. Good luck!
