Commander with Control Change
jedisteph
Post by jedisteph » Tue May 15, 2018 2:40 pm
Hello, is it possible to modify the Commander to send Control Changer rather than Program Change?
Steph
Re: Commander with Control Change
Post by JohnClark » Wed May 16, 2018 5:48 pm
You could make this happen using a MIDI Solutions Event Processor.
What exactly do you want to control that requires Control Changes?
jedisteph
Post by jedisteph » Thu May 17, 2018 6:08 am
JohnClark wrote:You could make this happen using a MIDI Solutions Event Processor.
Cool thanks.
I would like it to act like the GCP (which I have). I just need a smaller controller to switch HEX, commander is perfect except it only does setting changes (PC) rather then separate on/off for each loop. I do have presets for Commander/Hex but i'd rather have on/off switching.
I just want to be more portable with my rig when the GCP is not warranted.
Rig Floor Close copy.jpg (29.17 KiB) Viewed 1010 times
