Voodoo Lab control switcher - FXL8 Pro/LaneyIRT Studio
robobob
Post by robobob » Wed Jul 11, 2018 3:04 am
Hey Guys,
i am Max from Germany.
I wanted to know, is it possible to control the Laney IRT Studio (5 Pin no Midi), with the Harley Benton FXL8 Pro Switcher (also known as Joyo PXL Pro).
If i use the MIDI OUT of the FXL8 Pro Switcher, and connect it to the MIDI IN of the Voodoo Lab Control Switcher.
Then connect the MULTI Jack to the LANEY IRT FS-4 connector with a normal 5 PIN MIDI Cable.
Will this work for me to control the channels of the Laney IRT Studio?
What do I have to do on the FXL8 Pro in the MIDI Settings? I dont know the Parameters for Switching channels to the Laney IRT.
Or do I have to set up the MIDI Programm Changes between Voodoo Lab and FXL8 Pro?
thanks in advance
regards
Max
Re: Voodoo Lab control switcher - FXL8 Pro/LaneyIRT Studio
Post by JohnClark » Wed Jul 11, 2018 4:53 pm
This should work fine.
The Control Switcher will respond to MIDI Program Changes sent by the FXL8 Pro.
The Control Switcher will need to be programmed to enable MIDI Program Change Receive and the FXL8 Pro will need to be programmed to enable sending Program Change messages and both units will need to be set to use the same MIDI Channel.
The Footswitch jack on the Laney uses the same pin configuration as the MULTI jack on the Control Switcher so it will not need a custom cable other than using a MIDI Cable that has all five pins wired.
JohnTaru
Post by JohnTaru » Tue Aug 21, 2018 12:38 am
I have IRT and controlled by MIDI switcher.
You should buy RJM Amp Gizmo or Mini Amp Gizmo to make a MIDI command for your IRT (because 5 din port in IRT is not 5 pin MIDI port). That Gizmo's could make a command to changing channel to your IRT, also for engange boost and reverb too.
And dont forget to buy special cable that make from RJM to connecting IRT to Gizmo's.
Then connect that Gizmo's to your MIDI switcher.
Refer to Gizmo's manual.
I hope its help.
Thanks and greetings from Indonesia.
Best Regards,
johntaru
Post by JohnClark » Wed Aug 22, 2018 11:16 am
I hope its help.
Best Regards,
johntaru
The RJM switchers are also capable of controlling this amp, yes. However, Our Control Switcher, while having four switches rather than eight, is still fully capable of controlling the switching functions on the IRT amps, and in this case does not even require a custom made cable since the pin configuration is the same between our MULTI jack and the Laney Footswitch Jack... not to mention the original poster already has the Voodoo Lab Control Switcher ;)
