GCX Hum noise proble
BAJARACER
Post by BAJARACER » Thu Aug 16, 2018 8:47 pm
I have a GCX and out of the blue it starts to buzz really bad, I take everything out of the loops straight into the amp no change, tried cords, different this different that it does the same thing, its getting to the point of just getting rid of it
Any help would be appreciated
Mike
BAJARACER
Re: GCX Hum noise proble
Post by BAJARACER » Sun Aug 19, 2018 7:14 pm
Solved! Put some plastic washers between the GCX and the rack problem solved
Post by JohnClark » Mon Aug 20, 2018 11:02 am
If a ground loop was the issue, check out HumFrees Rack Isolation Tabs. These will not only isolate the rack ears from the rails, but they will also insulate the rack screw from the rack ears and keep rack devices isolated from each other.
