Two amps and a GCX?
brentalight
Two amps and a GCX?
Post by brentalight » Fri Jan 08, 2010 7:53 pm
Hopefully I'm not asking something already discussed or covered in depth here but....
I have a Lonestar Classic and Heartbreaker (both combos). Would I be able to control channel switching and also amp selection with the GCX and GCP? I invision switching between amps for different tones but also want to be able to use both at once for certain stereo scenarios. Can the GCX and GCP do this or should I be looking at other switching options? I would also want to be able to use a H&K tube rotosphere and memory man in the effects loops.
Plexico
Re: Two amps and a GCX?
Post by Plexico » Sat Jan 09, 2010 1:35 pm
Hi - there are some excellent setup diagrams that you might be able to utilize for this at the following link:
http://www.voodoolab.com/gcx.htm
I use a y cable (mono, not trs) out to switch....
Hope that helps.
