First of all I want to share a word of appreciation about what a great unit this GCP Midi controller is. It's very advanced, and yet very userfriendly! I have experience with the Behringer FCB1010 and that was a nightmare! This GCP unit just rocks!
I do have a question though (because I'm simply not sure if it's possible..think not but not sure... .)
I use the GCP to control a TC Gmajor2.
I'm using 4 presets per bank and instant access buttons.
Using this setup, I can select my solo preset, which has a bit of delay.
Now, I can use the instant access buttons to add some chorus, and remove it again.
Works fine.
One of the instant access buttons I use to set delay on/off. Now, on the Gmajor, this particular preset has delay implicitly enabled. Selecting the preset will enable the delay BUT, the delay instant access led is not illuminated. I guess this makes sense since the G-major is not going to tell the GCP "Hey! I got delay on..put on your little red light".
So I was wondering if it was possible to enable certain instant access buttons when selecting a preset in order to have the delay button illuminated when I called a preset which has delay. Same for presets with Chorus: Chorus LED is illuminated.
John Petrucci has a pedalboard which seems to be doing this. If you look around 1:49 he selects his clean preset, and you see a few led's getting enabled.
http://www.youtube.com/watch?v=Ot-zal0D ... re=related
Is this possible with the GCP? That would be awesome.. would make a great pedalboard the best for me
