It is currently Thu Jan 18, 2018 2:39 am
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Fri Oct 03, 2014 2:07 pm
Hey sorry if this has been answered;
I have the original pedal power;
Will this power the digitech Whammy IV and will it power the tc electronic flashback x4?
Wah
Whammy
PitchBlack
phase
flange
Delays OD
Jcm 800
Blackstar HT 50
5150 signature peavey & 50 watt 5153
http://www.myspace.pallor
http://www.myspace.com/falseflag7
PostPosted: Mon Oct 06, 2014 11:19 am
The Whammy IV requires AC power and cannot be powered from any of the DC outputs on the Pedal Power.
On the original Pedal Power, the Flashback x4 will require the use of a Current Doubler Adapter connected to any two outputs with the corresponding DIP switches set to the "ON" position.
PostPosted: Mon Oct 06, 2014 11:46 am
Ahhh the old AC that's right. Makes sense thanks, now is the AC plug on the back of the unit (PP1) isolated by chance?
Wah
Whammy
PitchBlack
phase
flange
Delays OD
Jcm 800
Blackstar HT 50
PostPosted: Mon Oct 06, 2014 12:03 pm
Sorry to exclude that part... You can power your Whammy IV from the Courtesy Outlet using the supplied adapter. As for it being "isolated"... yes, in that it is simply a copy of the Mains Voltage Input on the Pedal Power. It certainly isn't tied to any of the Isolated DC Outputs.
PostPosted: Wed Oct 08, 2014 4:05 am
Thanks john. There's a noticeable difference using the "courtesy plug". Nice to know this thing is still kicking since 1998.
Wah
Whammy
PitchBlack
phase
flange
Delays OD
Jcm 800
Blackstar HT 50
PostPosted: Wed Aug 03, 2016 4:54 am
Hi sorry if this has been answered already, but can I use oedal power 2, to power Pog 2 Harmonix Octave Generator?
PostPosted: Wed Aug 03, 2016 11:05 am
The Electro Harmonix POG 2 can be powered from output 5 or 6 on a Pedal Power 2+ with the corresponding DIP switch set to Normal.
If you have the older Pedal Power 2 (not +) then you would use a Current Doubler Adapter (the one with the Green end) connected to any two outputs with the corresponding DIP switches set to Normal.
PostPosted: Sun Jan 15, 2017 1:04 am
Boss SY-300 guitar synthesizer, requires 400mA, using PP2+ using the standard 2.1 cable with the PPAP current doubler into jacks 5 and 6, with the corresponding dip switches set to Normal, providing 500mA. Didn't power up with the dip switches set away from Normal.
PostPosted: Wed Feb 08, 2017 5:48 pm
No reason this shouldn't have worked... Are you sure you had our Current Doubler Adapter (the one with the Green end)?
Also, I just realized that this is almost a month old... sorry about that, I guess I didn't see you hiding up here in this thread :oops:
PostPosted: Tue Nov 07, 2017 11:33 am
Using an original first issue Pedal Power I am running the following Pedals;
Guitar into; D'Addario Tuner --> MXR 6 Band EQ --> EP-Booster --> S.D. Pickup Booster --> Morley ABY that splits the signal to;
A = CompTortion --> Hiwatt SA112 Bulldog
B = MXR EP-101 Echoplex Preamp --> MXR EP-103 Echoplex Delay --> Marshall 18w 2x10" Combo
The only Pedal not being powered using one of the 8 Outlets is the MXR EP-103 Echoplex Delay since in needs 250ma and the older units only put out 80ma.
