It is currently Thu Jul 19, 2018 6:50 am
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Wed Sep 23, 2015 9:52 am
DerekLarsson wrote:
Hi John, one more question here on recommended usage and current doubling.
I have a tube-based compressor (Effectrode PC-2A), that comes with its own power adapter, but it would be much more convenient to just get the power from the pedal power 2+ supply (and not use the adapter at all).
Its power requirements are documented as: 12VDC @ 350mA.
So I assume what I would need to do is get a current doubler cable, and then use outputs 5 & 6 together, with the switches set away from the normal position (for outputs 5, 6). If I understand correctly, doing this will then provide 12 volts and 400mA of current - which would be considered safe and be the advised, correct procedure for using this pedal, having that power requirement. 12VDC @ 350mA.
Can you reply back and confirm that what I posted (above) is the correct usage for this pedal? or if not......then set me straight on what I should do for this?
I want to make sure that I don't damage anything.
Derek
You got it! Right on!
PostPosted: Thu Sep 24, 2015 5:02 pm
Hi John, one more real important question. I forgot to mention that the Effectrode PC-2A connector has a Center Positive 2.1mm barrel connector.
The Pedal Power 2+ comes with one reverse polarity cable (red barrel), but it is documented as a 2.5mm barrel connector. Why the heck is this a 2.5mm barrel when all the other cable barrels are 2.1mm? Visually, I can't really tell the difference in size with my eyes. So I'm confused about that.
Is it possible to get a reverse polarity 2.1mm connector cable for this, and how do I get one? (part no, etc.)
Also, can you clarify which end of the cable (red?) would go into the pedal side (Center Positive 2.1mm), and which end would go to the power supply current doubler cable endpoint?
I look forward to your advice on this. Thanks for your help .....
Derek
Derek
PostPosted: Thu Sep 24, 2015 5:18 pm
Derek
No problemo!
The 2.5mm Red ended cable will fit into a 2.1mm jack, but may not provide a reliable connection. This cable is much more common but is mainly for use with the Line 6 Modeler pedals, Eventide Factor pedals, some EHX pedals and some Voodoo Lab switchers.
You would want to use our Reverse Polarity Barrel Cable. It will correctly fit 2.1mm jacks and it does not matter which end goes where.
PostPosted: Tue Nov 03, 2015 10:27 am
Can I jump in on the Effectrode PC-2A discussion?
Can you guys tell me exactly which cables I'll need to run this pedal from my PP2+?
It seems like I need both a voltage doubler and a 2.1mm center positive cable, yes? Which doubler cable should I get?
If you could post links to both cables that would clear up any confusion!
PostPosted: Wed Nov 04, 2015 6:34 pm
If you are using a Pedal Power 2+, you would use outputs 5 and 6 with the DIP switches set away from Normal connected together with a Current Doubler Adapter and with that a Reverse Polarity Barrel Cable to connect to the pedal.
 Post subject: Combining current doubler adapters?
PostPosted: Wed Dec 02, 2015 7:32 pm
Maybe I am missing it, but I have a question I can’t seem to find the answer to while searching through these forums.
Say I'm already using outputs 5 and 6 of a PP2+ to power pedals, and I still have an approx 300ma pedal I need to power.
Could I use a current doubler cable to combine outputs of 1 and 2, and then combine that with output 3 via another doubler cable to produce 300ma? Or is this not possible and/or frowned upon?
Thanks in advance for any help you can provide.
 Post subject: Re: Combining current doubler adapters?
PostPosted: Thu Dec 03, 2015 10:27 am
It is certainly possible. You could combine all the outputs down to one if you really wanted to ;)
It isn't necessarily frowned upon, it just isn't usually necessary. What exactly are outputs 5 and 6 being used for already, and what is this additional pedal?
 Post subject: is it ok to go 2mA over the stated output spec
PostPosted: Fri Dec 11, 2015 10:03 am
The high current outlets are used on my 4x4, and I want to add my Cali 76 at 18V using a 2 x 9V 100mA outlets on a voltage combiner cable. Is ok to run 1 pedal that runs at 18V 102mA current, which means it's 2 mA steady state over the 100 mA spec.
 Post subject: Re: is it ok to go 2mA over the stated output spec
PostPosted: Fri Dec 11, 2015 2:02 pm
This is a different cable than we are discussing in this thread here, however Origin Effects themselves say that our 100mA outputs will be fine. So you should be good to go!
PostPosted: Sat Aug 06, 2016 8:26 pm
