Pedal Power 2+ with newest model Bass Whammy
scottplaysbass
Post by scottplaysbass » Thu Mar 16, 2017 10:59 pm
I've been looking everywhere for this, and can't seem to find it (I may just not be looking hard enough).
I have the newest model Digitech Bass Whammy, which apparently is now 9vDC and runs at <265 mA (per the manual). Can I use the 5th/6th input on my PP2+ with the dip switch away from normal to power this pedal?
Thanks, I appreciate the info.
Re: Pedal Power 2+ with newest model Bass Whammy
Post by JohnClark » Fri Mar 17, 2017 1:15 pm
I would go with using output 5 or 6 with the corresponding DIP switch set to Normal.
We have been recommending using a Current Doubler adapter but recently we have found that these pedals are just fine on one of our 250mA outputs.
scottplaysbass
Post by scottplaysbass » Fri Mar 17, 2017 11:28 pm
Thanks John! I'll give it a shot and let you know if anything unusual happens.
