It is currently Wed Apr 25, 2018 11:02 pm
Author |
Message |
bettsaj
Post subject: Re: 60 Cycle Hum Posted: Wed Nov 08, 2017 2:48 am |
Joined: Fri Jun 11, 2010 12:13 pm Posts: 190 Location: Darkest Suffolk UK
Thanks john,
I'll have to rewire it slightly then, as currently I'm utilising both inputs in the tuner. one input is for the wireless, and the second input is wired to a front panel jack socket. If i use a guitar cable all i have to do is plug the cable into the socket and press the input selector on the front panel of the tuner.
Wiring your way will disable this functionality. I could still use it but using input 2 on the tuner wouldn't be benefiting from the GCX buffer so I'd likely get that noise again.
_________________ "My technique is laughable at times. I have developed a style of my own, I suppose, which creeps around. I'll never be a very fast guitar player."
David Gilmour
Top |
bettsaj
Post subject: Re: 60 Cycle Hum Posted: Sun Nov 12, 2017 3:59 pm |
Thanks John, all rewired as you suggested and it's working better than before.
For one, the noise has gone, but also it appears to have solved the issue I had with the lower volume from one of the channels... Which is odd.
The guitar is more dynamic with the buffer, I've only used it with a guitar cable so far, and haven't tried the wireless... Although I don't expect it to not be OK.
Thanks John, you have once again proved your wizardry
David Gilmour
Top |
Post subject: Re: 60 Cycle Hum Posted: Mon Nov 13, 2017 12:58 pm |
Joined: Tue May 05, 2009 2:33 pm Posts: 6966 Location: The Lab
Right on! Now turn that rig up... I want to hear it from across the pond!
Top |
Who is online |
Users browsing this forum: No registered users and 5 guests |
