Rack on its way
Marlboro05
Re: Rack on its way
Post by Marlboro05 » Wed Mar 20, 2019 2:07 pm
Hi there,
I did a re-jig again, I took out the Switchblade 16, they take so much away. Now the whole preamp section can push the power amps harder. It sounds so much better. I have utilised the Rane Mixer again and glad I have, TC Electronic G Major 2 is in the loop of the SM82S.
I’ve got the Recto Recording and 2:100 totally seperate now, they do their own thing but it is still controlled by the GC Pro’s and the Mini Switch Gizmo.
The rest of the system is controlled by the GCX, Voodoo Gear Rocks!!
I have changed the order to make wiring a lot easier and more tidy!!
I have rewired the pedal drawer to tidy it up a bit!!
Well hope you guys and gals like the pics.
And some other stuff.
Marlboro05
Re: Rack on its way
Post by Marlboro05 » Fri Oct 18, 2019 3:53 pm
Well I’ve been at it again and switched it all around. I have 2 different racks now each with its own power supply, power amp and 2 preamps. Just need another couple of cabs😛
It’s not as good as Nice Rack Canada, but hey, it’s alright.
Re: Rack on its way
Post by JohnClark » Mon Oct 21, 2019 2:00 pm
Hey man, Nice Rack!
YakForger
Re: Rack on its way
Post by YakForger » Wed Nov 27, 2019 10:46 pm
Looks lik an awesome battlestation! I'm still far from it, but I hope I'll reach that level some day!
Marlboro05
Re: Rack on its way
Post by Marlboro05 » Wed Dec 18, 2019 1:42 am
Cheers John🤘
Marlboro05
Re: Rack on its way
Post by Marlboro05 » Wed Dec 18, 2019 1:43 am
Cheers Yak, it goes alright.
Just grab stuff when it comes up cheap or do some haggling. You’ll get there😝😜
Marlboro05
Re: Rack on its way
Post by Marlboro05 » Sun Aug 30, 2020 6:28 am
Here’s the latest setup
Sytravis
Re: Rack on its way
Post by Sytravis » Sun Aug 30, 2020 10:02 am
With massive thanks to marlboro05, my rig is working after installing the GCX.
All I need now, is the ampete amp & loop switch, and I hopefully will be done.
Rig so far.
Currently I run between 2 heads, although the 3rd is on the way. Just need a really good switcher that will switch amp, so I can use 1 fx rack, and a couple cabinets.
Still have the option to add a few more pedals to the fx tray if needed
Sytravis
Re: Rack on its way
Post by Sytravis » Sun Aug 30, 2020 10:06 am
Couple more pics
Marlboro05
Re: Rack on its way
Post by Marlboro05 » Sun Aug 30, 2020 2:52 pm
Awesome rig you’ve got there👌
Need to get myself a couple of those Mesa 2x12 cabs.
