Effectrode, Mini Vent, Chrono Delay
helletused
Post by helletused » Mon Mar 18, 2019 8:01 am
Hello, does the mondo power all those pedals?
PC-2A 12V 600mA
Mini Vent 12V 180mA
Providence Chrono Delay 12V 110mA
the mondo outputs 5-6 with dip switches on give unregulated 12-16V 250mA. Do the mini vent and chrono delay survive this?
Thank You,
best wishes, Paul
Re: Effectrode, Mini Vent, Chrono Delay
Post by Rez » Mon Mar 18, 2019 11:01 am
Yes, Pedal Power Mondo will power them all, setup:
To power the PC-2A Compressor use a 12VDC high current capacity (400mA) output with a 2.1mm Reverse Polarity Barrel Cable, part# PPREV, PPREV-R. Note, the actual current draw of PC-2A is less than 400mA.
To power the Mini Vent use the Mondo output labeled 5 or 6, DIP switch in the 12V mode (set away from NORMAL) with a 2.1mm Reverse Polarity Barrel Cable, part# PPREV, PPREV-R
To power the Chrono Delay use a 12VDC high current capacity (400mA) output with one of the all black (standard polarity) cables supplied.
helletused
Post by helletused » Tue Mar 19, 2019 1:02 am
Yes, it works! Thanks, Paul
Post by Rez » Thu Mar 21, 2019 2:20 pm
Awesome!
