General discussion and tech talk about the industry standard Pedal Power line of power supplies.
monk
Post
by monk » Mon Apr 19, 2010 11:52 am
I just got the Diamond Memory Lane. I know I need the 18 volt reverse polarity cable. The problem is I´m already using output 5 and 6 to power my Replica and Suhr Minimix II. Can I use output 1 and 2 set to 12 volt and still get enough mA to power the Memory Lane? Otherwise I need to use a separate powersupply.
I´ve got a GCP, two PP2+ and a Iso-5 in my rig now. I really like your products.
Thanks.
Post
by JohnClark » Mon Apr 19, 2010 12:35 pm
Using the 18V Y cable on any two outputs of 1-4 with the DIP switches set away from Normal will yield 24V with about a 100mA limit. Because outputs 5 and 6 are already in use, your Memory Lane should be powered from the Courtesy Outlet on the back of the Pedal Power 2+ using the supplied adapter.
monk
Post
by monk » Mon Apr 19, 2010 1:03 pm
Thanks for the reply. The supplied adapter is actually 24 volts but 400mA. I couldn´t find any information about the minimum mA to power it.
