back rig pics needed !!!! if you use more then 1 head or pre
Mark_30
Post by Mark_30 » Wed Jul 06, 2011 8:26 am
HI
Im building mi rig right now and it's kinda hard ...
Anyone as a multiple pre-amp / head set up goiing trought a power amp ??
In fact any pics of rig from behind 8-) .. would be great .. ! :D
Just to figured out the real set - up !
Tx guys !
Im posting myne as soon as it's all wired !"
Re: back rig pics needed !!!! if you use more then 1 head or
Post by JohnClark » Wed Jul 06, 2011 10:28 am
Not exactly a picture of a rack, but here is a diagram that has GCX Loops 1 and 2 being used to switch between three preamps...
http://www.voodoolab.com/gcxdiagrams/04 ... werAmp.pdf
Also, in the GCX manual under the Audio Loops section is a diagram for A/B Switching between two preamps (Example 1) as well as a diagram for switching between two amplifier inputs (Example 2).
...and make with some pictures already! ;)
carstenlange
Post by carstenlange » Sun Sep 07, 2014 7:50 am
Bumping this as I think its good for cable management ideas and getting ideas on out to go about things.
here is a good link
http://www.hugeracksinc.com/forum/viewt ... =1&t=94582
Custom Audio Amplifiers PT100
Bogner Ecstasy 101B
Carvin electric guitars
