Triaxis, Mini Amp Gizmo Rack Setup
Marlboro05
Post by Marlboro05 » Thu Sep 10, 2015 11:54 pm
Hi there all, this is my first post so I thought I'd see if I can get some suggestions on a little rack setup.
I have a couple of bits in my rack as follows
Triaxis
Gmajor 2
Mini Amp Gizmo
GCX
All controlled via GCPro
I don't have a Power Amp, Mesa 2:90 or 2:100 would be awesome, so was thinking of using both my Dual Rectifier's and Stiletto Deuce's power side in a stereo setup as I have 2 cabs and using the Triaxis and Dual Rectifier(and maybe even the Stiletto) as preamps. I have the Mini Amp Gizmo and cable to switch the Rectifier via MIDI. I have a heap of other FX pedals/multi FX aswell. Was thinking I'd put my NS-2 in front to.
Cheers Brett
And some other stuff.
Re: Triaxis, Mini Amp Gizmo Rack Setup
Post by JohnClark » Fri Sep 11, 2015 10:48 am
Here is a GCX setup that switches between one of three preamps before going to some stereo effects before hitting a power amp.
http://www.voodoolab.com/gcxdiagrams/04 ... werAmp.pdf
Your rig wouldn't be much different tan this except that you will use the Effects Returns on your two amps as the Power Amp ins.
I hope this helps!
