Adapter cable PP2+ to Morley SLWV Wah/Volume
Sander
Post by Sander » Fri Aug 04, 2017 3:59 am
my Morley SLWV is powered by 12 to 18 volts DC out of what appears to be a small jack plug, tip positive. To do this using my PPP2+ I assume I would need a y-cable with 2 5.5x2.1mm barrel connectors on one end and a small jack plug on the other.
Are any such cables available on the market? If so, where?
Apart from making such cable myself, any other easy solutions?
I considered using two cable with battery snaps, but the way the battery compartment is placed on the bottom side, with a metal plate covering it makes that not a great solution.
Any help appreciated!
Re: Adapter cable PP2+ to Morley SLWV Wah/Volume
Post by JohnClark » Fri Aug 04, 2017 11:33 am
The allowable voltage range can help here. For 12V operation you would use any one of outputs 1-4 with the corresponding DIP switch set away from Normal. Output 5 or 6 with the corresponding DIP switch set away from Normal would probably provide about 16V to this particular pedal. There is a Mini Plug Cable that comes with the Pedal Power 2+ that should work for this.
If you wanted to run specifically at 18V you could use the Mini Plug Cable together with our Voltage Doubler Adapter connected to any two outputs with the corresponding DIP switches set to Normal.
Sander
Post by Sander » Mon Mar 26, 2018 10:22 am
Thanks, that worked like a charm! Output 5 with switch away from normal gives me all the wah I could ever need.
And on the side I learn a valuable lesson about looking further than my nose's length ;-) ;-).
Wonderful, thanks again!
