Looking at the 4x4
RosieRox2017
Looking at the 4x4
Post by RosieRox2017 » Mon Sep 18, 2017 9:47 am
Looking at getting the 4x4 but I have a few questions that hopefully people can answer for me. I currently have a PP2 plus under my old PT-2 board. Will the 4x4 fit under those old pedaltrain that just have the two holes in the front and not the open front? And can I use the same mounting brackets? I'm also looking at powering 9 pedals whith it. That's including a timeline and a big Sky, howerever i may need to be able to power a couple more. How may of the outputs can I feasibly use a splinter on? Thanks!
Re: Looking at the 4x4
Post by Rez » Fri May 18, 2018 5:54 pm
Yes, Pedal Power 4x4 can be mounted as you suggest (using the same brackets... but spaced a bit further apart).
Also, it theory all isolated outputs could be split. And, adding a couple splitters usually work great. That said... I'd split as few as possible as one-pedal-per-one-output is the optimal configuration.
