Output jack broke off on my GCX..
lodybo
Post by lodybo » Tue Nov 21, 2017 5:49 am
Hi!
The output jack of my Voodoolab GCX broke off recently after gigging.
I wanted to try and repair it, but noticed that the connector chassis of the jack plug has 3 prongs on the bottom.
I've searched for it but haven't come across a similar plug that I can purchase, only the (more standard) kind which has one prong on the bottom and 2 at the back.
Is this chassis Voodoolab-specific, or am I just looking in the wrong place?
Thanks in advance!
Re: Output jack broke off on my GCX..
Post by JohnClark » Tue Nov 21, 2017 12:00 pm
Feel free to give us a call or write an email to info@voodoolab.com and we'll get you the correct jack if you would like. Otherwise you can set up a return and we can fix it for you as well as check out the whole GCX.
lodybo
Post by lodybo » Wed Nov 22, 2017 1:05 am
Awesome! Sending you an email now :)
lodybo
Post by lodybo » Mon Nov 27, 2017 1:31 am
JohnClark, I sent you guys an email last week but haven't heard back sadly..
I sent you another one this morning. If necessary, I can provide you with pictures from the board when I opened it up.
Post by JohnClark » Mon Nov 27, 2017 1:03 pm
lodybo wrote:JohnClark, I sent you guys an email last week but haven't heard back sadly..
Sorry, you were likely a victim of unfortunate timing... we have been closed for the Thanksgiving Holiday here.
lodybo
Post by lodybo » Tue Nov 28, 2017 6:38 am
Understandable, no problem :)
I just replied to your email, so if all goes well the jack should be on its way in no time!
