OCD with Pedal Power 4x4
hamabdullah
Post by hamabdullah » Mon Dec 04, 2017 12:44 am
Hi Labgods,
need help to place OCD on the 4x4 as I've been getting mix answers reading thru the forum.
Where can I place the OCD with the 4x4? Can I put it on the 9v or the 9v high 400ma area? please help
Re: OCD with Pedal Power 4x4
Post by JohnClark » Mon Dec 04, 2017 4:35 pm
The OCD will accept 9-18V DC so it can be powered from any output on a Pedal Power 4x4, 9V or 12V. If you wanted to run it specifically at 18V you will need a Voltage Doubler Adapter connected to any two 9V Outputs.
For the current rating, a pedal will only draw the amount of current it needs to operate. The OCD somewhere around 10mA so it would be equally fine from either the 100mA or 400mA outputs.
