Voodoo lab control swither for change ampli channel
luciopooh
Post by luciopooh » Sat Oct 20, 2018 4:22 am
Sorry for my english (i'm italian) Ok I try to ask the same
I bought the voodoo lab control switcher to connect it to the Pod and change the channel of my amplifier that has no Midi input but a simple switch with input Jack I had seen on YouTube the possibility to do it but does not explain the connections or programation, I inserted the cable Midi in the Midi out of the Line6 Pod the other end of the Midi cable in the input In of the voodoo lab switcher, then always from the Voodoo Lab switch came out with the stereo jack cable inserted in the input of the changer of my amp on the pod I set program change channel 1 but nothing happens absolutely You can give me a hand Surely something wrong
Re: Voodoo lab control swither for change ampli channel
Post by JohnClark » Mon Oct 22, 2018 3:01 pm
Sorry for the trouble!
Does the amp do anything when pressing the buttons on the Control Switcher?
