Will GCX Phantom Power a BJ-Devices MIDI Controller?
nyteowl
Post by nyteowl » Mon Jan 28, 2019 1:31 pm
I'm rather confident I've got this right, but it's been so long I want to run it past the forum to be sure.
I got away from rack gear for quite a while, but recently picked up an older DMC GCX. It's so old it has both a 4-pin power connector and a female barrel jack power input as well. I want to use it with a BJ Devices TB-6P MIDI Foot Controller - for the smaller footprint - and want to phantom power the TB-6P via the MIDI Cable.
As I understand it, the
Using the GCX without a Ground Control section on Page 14 of the GCX User's Manual indicates Pins 1 and 3 of a 5-pin MIDI Cable are used to supply power to the GCPro, and the TB-6P User's Guide states:
Phantom power is received at MIDI OUT port of the controller. Please note that we use 5 pin (NOT 7 pin) MIDI OUT port that receives phantom power on pins 1 and 3, polarity doesn't matter."
Given that, I'd say I'm good to go, no?
Marlboro05
Re: Will GCX Phantom Power a BJ-Devices MIDI Controller?
Post by Marlboro05 » Tue Jan 29, 2019 6:04 am
Hi Nyteowl,
Yes it will, should be plug and play. Well, sort of.
And some other stuff.
nyteowl
Post by nyteowl » Wed Jan 30, 2019 6:22 am
Hi Nyteowl,
Thanks for the vote of confidence. I'm just getting the new rack organized, and should have it up and running soon.
