Search found 1 match
by jrichview
Sun Mar 19, 2017 11:18 am
Forum: Racks, Switching Systems and MIDI
Topic: Ground Control Pro + Eleven Rack Expansion Pack
Re: Ground Control Pro + Eleven Rack Expansion Pack
JohnClark wrote:The Eleven Rack Template for the Ground Control Pro loads the preset names for the default patch names... basically, the names of the user bank patches as they were when you first pulled the Eleven Rack out of the box. The template is just a quick way to get started when this is all new to you.
If you have changed the patch names on the Eleven Rack User bank, then you will also have to manually change the preset name name on the Ground Control Pro if you want them to match. Complete instructions on how to do this are found under Edit Preset within the Ground Control Pro manual in the Naming Presets section.
Sorry for the lateness of this question. I realize this is "so 5 minutes ago", but I just got a GCP and I'm interested in seeing if I can finally use my 11R in a live situation. I got the template loaded, so thanks for providing that.
I understand clearly that this is just a setup for the presets, but my question is this: I would like to be able to quickly switch between the user banks and the preset banks on the 11R. Right now it appears to me that if I wanted to do this, I would have to hit the bank button 20-something times to get from a preset bank to a user bank. Is that correct, or is there some tricky/cool way to assign one button to take me from the preset banks to the user banks and back?
