Search found 2 matches
- Mon Mar 25, 2013 5:42 pm
- Forum: Racks, Switching Systems and MIDI
- Topic: Ground Control Pro +Eleven rack sweetwater patch memory dump
Re: Ground Control Pro +Eleven rack sweetwater patch memory
my apologies if something was not quite where it should be... hehehehe when i got my eleven rack i had troublke figuring out the output settings... in other words all the presets sounding pretty samo...what i didnt realize was the outputs were not set for amp use , i was just getting the clean input signal ...to make a long story short i used my line 6 mentality quotient and reset the memory... i had to re install all the sweetwater presets and they may have not dumped in the same order they were when i got it but at least this will get folks started ...enjoy...
- Sun Mar 24, 2013 3:02 am
in case you have a sweetwater eleven rack..here are the patch dumps for the artist presets and a few of the factory up until number 127...
